Measurement Studio for VB6
Hi Brian,Why is it so awful from PCI 6052E card generated sine wave signal in measurement studio with visual basic 6.0?
I have performed you provided illustration,but it is so awful from PCI 6052E card generated sine curve,and it is really that the illustration couldn't change the amplitude of signal.
Would you please tell me about these?
I hope receive your reply ASAP!
(5,794 Views)
I tried a shipping example I found at:
C:\Program Files\National Instruments\NI-DAQ\Examples\VBasic\Ao\WFMsingleBufAsync
I used a similar E-Series device with 2 16bit analog output channels. I works fine, and it allows you to change the amplitude with the function WFM_Scale. Attached is the example.
(5,794 Views)
