Measurement Studio for VB6
How do I read temperature from K-type thermocouple using Trandiational DAQ and VB 6.0
Hi
     I have a Tranditional DAQ. I wanna read temperature or voltage from my k-type thermocouple. How can I write a program with VB 6.0? Are there any examples??
            Thank you!
      regards
                      ye
(7,100 Views)
Hello ye,
What device do you have?  Are you certain that you must use Traditional NI-DAQ with it?  You can check driver and device compatibility at http://www.ni.com/support/daq/versions.htm
Examples do install with both NI-DAQmx and Traditional NI-DAQ for VB6.  See the directory C:\Program Files\National Instruments\NI-DAQ\Examples
The folder named Visual Basic 6.0 has NI-DAQmx examples.  The folder named VBasic has Traditional NI-DAQ examples.  The examples should help you get started.  If you need help with a particular function call, see the reference help files at Start >> Programs >> National Instruments >> NI-DAQ >> Traditional NI-DAQ Function Reference Help or NI-DAQmx C API Visual Basic 6.0 Help.
Laura
(7,088 Views)
Hello Laura,
I am also looking for some example to control NI 6527 board using VB 6.0. I went to the directory you have mentioned above, but could not find those examples. Would you mind telling me if they are available somewhere in the web?
Ananda
(6,998 Views)
Ananda,
See my reply here.
(6,977 Views)
