Measurement Studio for VB6
How to save data from a channel test run
How can I save the data that appears when I test a virtual channel?
(6,806 Views)
Have you checked out the examples in "C:\Documents and Settings\All Users\Documents\National Instruments"  folder?   It sounds like you're acquiring data from a "virtual channel" set up using DAQmx, or through the measurment and automation explorer, is this correct?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(6,758 Views)
