Measurement Studio for VB6
I'd like to generate a sine wave signal from PCI 6052E card in measurement studio with visual basic 6.0!
I'd like to generate a sine wave signal from PCI 6052E card with measurement studio for visual basic 6.0,it is only 500mv/1KHZ,could you give me a illustration about the one?In addition,go to " C:\Program Files\National Instruments\MeasurementStudio\VB\Samples\DAQ\_GettingStarted\" Ao.example that generated sine wave is very awful,could you help me how to use PCI 6052E card 's two analog output port?
Thanks a lot!
Wait for your reply!
(5,839 Views)
Hi Kelven,
There's a helpful tutorial on this at this URL:
http://zone.ni.com/devzone/conceptd.nsf/webmain/9C9F9227D165EF6C8625687E006CEFF5?opendocument&Submitted&node=DZ52130_US
Additionally, this example uses ActiveX to do waveform generation in VB on one channel:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DCD156A4E034080020E74861&p_node=DZ52130&p_source=External
The file attached below is an example that will do waveform generation on multiple channels.Hope this helps!
Brian Spears
(5,839 Views)
