I hope someone can help me to clarify this.
I'm developing an application to continuously acquire numbers of analog input channels from SCXI-1102B and SCXI-1327 modules.
I chose CWAI controls for the task simply because I like the CWAI_AcquiredData() event, although I know I should at least use VB6 with DAQmx function calls.
However, after I read the message
I feel very much confused and have doubt about the choice I made. It seems that in order to have CWAI control functioning properly, I need to have the traditional DAQ driver 7.4.1.or earlier. I know for sure that I have DAQmx 7.5 installed, I also suspect the traditional DAQ driver is installed as well, as I can see all the CW ActiveX controls (include DAQ) from the Visual Basic aplication. What makes things more confused is that I have installed both the 'NI Mesurement Studio 6.0 + Updater' and 'NI Mesurement Studio 7.1 for .NET'.
How can I find out the version(s) of the DAQ drivers? If I keep the CWAI control, will it be an issue in the future when the application is distributed to another PC considering that a Traditional DAQ driver is needed?
Thank you,
LogicT
