01-27-2006 08:18 AM
01-30-2006
02:04 PM
- last edited on
07-10-2025
04:18 PM
by
Content Cleaner
Hi!
I have not had any problems running the TDAQ example programs. I am also using DAQmx 8.0 and T-DAQ 7.4.1 and VB6. There may be something corrupt with your installation. I recommend uninstalling and reinstalling the drivers. Just to be sure that you have a clean install, you should download the latest drivers from the Drivers and Updates page.
Let me know if you are still having problems!
Micaela
01-31-2006 03:26 AM
01-31-2006
02:33 PM
- last edited on
07-10-2025
04:19 PM
by
Content Cleaner
This KB talks about the nidaq32.dll file not found error.
Let me know if that doesn't fix the problem.
02-03-2006 05:08 AM
palBase -b 64000000 -s 44000000 command resolved the problem in both PCs.
02-06-2006
09:30 AM
- last edited on
07-10-2025
04:21 PM
by
Content Cleaner
Hi Dimitri,
There are specific use cases for the Traditional NI-DAQ driver; however, the Traditional NI-DAQ driver is not as reliable as the NI-DAQmx driver. The Answers to Frequently Asked Questions abut NI-DAQmx and Traditional NI-DAQ explains the use cases and differences between the two drivers.
I highly recommend developing for the NI-DAQmx driver and only using the Traditional NI-DAQ driver when necessary.
Regards.
