11-17-2010 09:48 PM
I have the following code written in VB.Net using NiDAQmx. I have the need to have the same code written in VB6. Can someone give me the equivalent calls in VB6 using NiDAQmx?
Imports NationalInstruments.DAQmx
Public Class frmDIO
Private sPort As String = "Port1"
Private sDevices() As String = Nothing
Private sOutputLines() As String = Nothing
Private sInputLines() As String = Nothing
Private sPorts() As String = Nothing
Private sSerialNumber As String
Private sDeviceID As String
Private Sub frmDIO_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
Dim sDAQDevice As String
Dim sDAQPorts As String
Dim sString As String
sDevices = DaqSystem.Local.Devices
sPorts = DaqSystem.Local.LoadDevice(sDevices(0)).DOPorts
For Each sDAQDevice In sDevices
cbDigitalIOCard.Items.Add(DaqSystem.Local.LoadDevice(sDAQDevice).ProductType & " " & DaqSystem.Local.LoadDevice(sDAQDevice).DeviceID)
Next sDAQDevice
cbDigitalIOCard.Text = cbDigitalIOCard.Items(0)
For Each sDAQPorts In sPorts
cbPort.Items.Add(sDAQPorts)
Next sDAQPorts
cbPort.Text = cbPort.Items(0)
End Sub
Private Sub PortValue_Changed(ByVal sender As Object, ByVal e As System.EventArgs) Handles Port1.PortValueChanged
Dim digitalWriteTask As New Task()
Dim OutputChannel As DOChannel
Dim bInvertLines As Boolean
Dim iSlashPos As Integer = cbPort.Text.IndexOf("/")
Dim sPortName As String = cbPort.Text.Substring(iSlashPos + 1, cbPort.Text.Length - (iSlashPos + 1))
If Port1.Inverted Then
lblPortValue.Text = 255 - Port1.State
Else
lblPortValue.Text = Port1.State
End If
OutputChannel = digitalWriteTask.DOChannels.CreateChannel(cbPort.Text, sPortName, ChannelLineGrouping.OneChannelForAllLines)
("Dev1/Port1/Line0", "Line0", ChannelLineGrouping.OneChannelForEachLine)
digitalWriteTask.Start()
bInvertLines = OutputChannel.InvertLines
digitalWriteTask.Stop()
OutputChannel.InvertLines = Not chkPortInversion.Checked
Dim writer As DigitalSingleChannelWriter = New DigitalSingleChannelWriter(digitalWriteTask.Stream)
writer.WriteSingleSamplePort(True, Decimal.ToUInt32(lblPortValue.Text))
digitalWriteTask.Dispose()
End Sub
End Class
11-18-2010 06:49 PM
Hi Tim,
You should be able to find all the examples and the documentation you need under the Program Files>National Instruments>Measurement Studio in your computer.
11-18-2010 07:01 PM
I've already looked. There is nothing there for VB6...
11-23-2010 07:06 PM
Sorry Tim,
I meant to say that you should look on this directory:
<>\National Instruments\NI-DAQ\Examples\DotNET2.0\
When you select the examples, you will see that you can choose from visual basic or C sharp.
