Measurement Studio for VB6
Pb Calibrating DSA NI4552 with Daqtools.CalibrateDsa : Err 10003
I'm trying to calibtrate an NI4552 DSA Board with DaqTool in VB by the DSACalibrate function :
CWDAQTools1.CalibrateDSA 2, cwCalDSAOpInternal, 7
It raise an error 10003. I don't understand why.
Thanks for your help.
(3,353 Views)
The error 10003 is a general NI-DAQ error that can be found in the NI-DAQ Help file, which says "The value of a numeric parameter is invalid." This means that one of the parameters in the function that is giving this error is not allowable. Make sure that you are entering the correct device number and that it's the same device number as the one in the Measurement and Automation Explorer. Also, you may try to calibrate to some different voltage values, such as 5 Volts or lower.
(3,353 Views)
