Measurement Studio for VB6
Programming PCI-6602 in visual basic 6.0
i have a pci 6602 counter timer board and would like to write the program in visual basic 6.0.  Can someone point me in the direction of were i can get thorough information on how to set up the interanl clock source of 80MHz and then get the times from the Gate lines that are aquiring external stop pulses.
(6,951 Views)
Hi Joe,
Please refer to the following document for DAQmx VB6 support.
NI-DAQmx Support in Visual Basic 6.0
 If you have installed support for Visual Basic 6.0 when installing NI-DAQmx you should see examples in the NI-DAQ folder as shown in the KnowledgeBase article above.
Abhinav T.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(6,941 Views)
