Measurement Studio for VB6
Question about the Ni-DAQ function used in VB
thanks for the previous answer first!
I found that my computer has not installed the Measurement Stduio. When i wanna add module with file nidaq.bas, it shows nothing. Therefore, i download this file and nidaqcns.inc file from the web. Then i add them into VB project.
When i use the function, as i don't how to use them. I just simply copy the "AI_Change_Parameter (deviceNumber, channel, paramID, paramValue)" and see the effect. But it states that "invalid outside procedure". Thereafter, i try just input 1 instead. same statement arouse.
So, my question is how to use them, because i don't have the example.
Thank you very much
(3,117 Views)
It's hard to say for sure without seeing some code, but it sounds like you might be calling the function outside of a subroutine or function. Please verify that the call to AI_Change_Parameter is in a subroutine or function and if you're still getting the error, please post the code that's causing the error. Thanks.
- Elton
(3,117 Views)
