thanks for the previous answer first!
I found that my computer has not installed the Measurement Stduio. When i wanna add module with file nidaq.bas, it shows nothing. Therefore, i download this file and nidaqcns.inc file from the web. Then i add them into VB project.
When i use the function, as i don't how to use them. I just simply copy the "AI_Change_Parameter (deviceNumber, channel, paramID, paramValue)" and see the effect. But it states that "invalid outside procedure". Thereafter, i try just input 1 instead. same statement arouse.
So, my question is how to use them, because i don't have the example.
Thank you very much
