Measurement Studio for VB6
Reading NI 9203 module in cDAQ-9178 chassis using VB6
Hi Chris,
I am pleased the hardware is working without issue and hopefully this will take care of the software error so you may successfully move forward.  Below is a screenshot comparison of the DAQmx C Reference Help and the current example previously referenced parallel to your line of code.  It appears that you are passing a string in place of a number for the shunt resistor value (indicated in red).  If a number is expected and a string is passed, then I anticipate this would produce a type mismatch error like you are seeing.  Let me know if you are still experiencing difficulty after this substitution.
h_baker
Message 11 of 14
(3,659 Views)
SUCCESS!!!  I was under the impression that if you were using the internal shunt resistor in the module itself you did not need to specify a resistor value.  You absolutely do.  Here is the code that works:
DAQmxErrChk DAQmxCreateAICurrentChan(taskHandle, "cDAQ1Mod2/ai0:7", "", DAQmx_Val_Cfg_Default, 0.003, 0.02, DAQmx_Val_CurrentUnits2_Amps, DAQmx_Val_CurrentShuntResistorLocation1_Internal, 249.0, "")
With that being said, do you happen to know the acutal resistor resistance in the NI 9203 module itself? That is the number I would like to use instead of the default 249.0, if it even matters.
Thanks for all your help on this one...
Message 12 of 14
(3,649 Views)
Message 13 of 14
(3,649 Views)
Hi Chris-
     The manual does not specify a resistor value.  Are you looking for a shunt resistor value?  I am unfamiliar with what your application is specifically, but I am fairly sure that would be an external resistor.  The 9203 input impedance is 138 Ohms, if that helps.
     Have a great day!
Gary P.
Message 14 of 14
(3,628 Views)
