Measurement Studio for VB6
Searching someting like "CVI ProcessSystemEvents" in MFC
Hallo,
Is there any functionality like the CVI function ProcessSystemEvents in the
MFC, or have I to use multi threading?
thanks
Babak
(3,121 Views)
Babak,
The MFC analog to CVI ProcesSystemEvents is a message loop. Check out the MSDN article titled "Idle Loop Processing" for more information. The URL for the online MSDN is below.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/vccore/html/_core_Idle_Loop_Processing.asp
David Rohacek
(3,121 Views)
It sounds like you're looking for something like VB's DoEvents. One way to do this in MFC is something like this:
void CMyClass::DoEvents()
MSG msg;
while (::PeekMessage(&msg, NULL, 0, 0, PM_NOREMOVE))
if (!::AfxGetThread()->PumpMessage())
return;
You can find some additional useful information from these Microsoft Knowledge Base articles:
Q74042 - HOWTO: How to Use PeekMessage() Correctly in Windows
Q99999 - INFO: Background Processing in an MFC Application
- Elton
(3,121 Views)
