Measurement Studio for VB6
Value property
I'm using vb.net with cw and was just wondering what the difference is from an object.value and object._value
Curt
(3,325 Views)
What's an example of where you see object.value and an example of where you see object_value in the interop assemblies?
- Elton
(3,325 Views)
I'm using a CWKnob with value pairs to control some settings on a signal analyzer
ex
StartFrequency is the name of the control
StartFrequency.Axis.ValuePairs.Item(StartFrequency.ValuePairIndex).Value
the options in the popup window after the item index value
are Name, Value and _Value
It's not that important, I'm just curious.
Curt
(3,325 Views)
Sorry ... I misread your original message. I thought it said object_value instead of object._value (I missed the period).
Anyway, the _Value property comes from the type library. If you look at it in OLE View, you'll see it's defined like this:
[id(00000000), hidden, helpcontext(0x000001f4)]
VARIANT _Value;
It's attributed as hidden, so you don't see it in VB. The hidden attribute is dropped when the type library is imported into .NET.
The reason for the _Value property is that it's defined as being the default value in VB. Default values for properties are not supported by VB.NET or C#. You could use _Value or Value, but I recommend preferring Value.
- Elton
(3,325 Views)
