Measurement Studio for VB6
Using AxCWArray in ComponentWorks 3.0.1 with VB .Net 2002
When I ran a VB code in Visual Studio .NET 2002 using AxCWArray, an error message popped up:
An unhandled exception of type 'System.Runtime.InteropServices.COMException' occured in macorlib.dll. Addtional information: Catastrophic failure.
Here is the example code:
Dim a(4, 5) As Double
Dim j, k As Integer
Dim l As Integer = 0
For j = 0 To 4
For k = 0 To 5
a(j, k) = l
l += 1
Dim result() As Double
result = AxCWArray1.IndexArray(a, New Object() {2, DBNull.Value})
result = AxCWArray1.IndexArray(a, New Object() {DBNull.Value, 1})
Any comment?
Rong Zhu
Tyco Telec
ommunications
(6,021 Views)
Could you please post a test project that reproduces this error? I created a new project, added a CWArray control to the form, added a button, added an event handler for the button's click event, and copy & pasted your code. This worked fine on my machine.
- Elton
(6,021 Views)
Elton,
Thank you for answering my question. I tried the AxCWArray ActiveX control, and it works. In my original code generating the error message, I used the control class: CWArray, and sorry for the confusion. Here is the code:
sub test()
dim CWArray1 as CWInstrumentControlLib.CWArray
CWArray1 = new CWInstrumentControlLib.CWArray
Dim j, k As Integer
For j = 0 To 4
For k = 0 To 5
a(j, k) = l
l += 1
result = CWArray1.IndexArray(a, New Object() {2, DBNull.Value})
result = CWArray1.IndexArray(a, New Object() {DBNull.Value, 1})
end sub
Rong Zhu
(6,021 Views)
