Measurement Studio for VB6
Using CNiGraph, how do I reset the X Axis back to zero?
I am using a CNiGraph as a strip chart.  Calling ClearData() clears out the graph, but how do I set the X Asis back to zero?
TIA
Eric
(6,628 Views)
Hi Eric,
There are several methods such as SetMinimum() and SetMinMax() that you can use to reset the X-Axis back to 0. For example, to set the X-Axis to a minimum value fo 0 you could say,
 m_graph.GetAxes().Item("XAxis").SetMinimum(0);
Or  you could use the SetMinMax() method and say
 m_graph.GetAxes().Item("XAxis").SetMinMax(0, 200);
Hope this helps!
Best Regards,
Jonathan N.
(6,615 Views)
Thanks Jonathan.  I know it had to easy!
Eric
(6,614 Views)
