Measurement Studio for VB6
Want to us CWGPIB control as NOT CIC
Greetings...
I am using a PCI-GPIB+ card with a Measurement Studio 6 CWGPIB control. The application I have is to use this card (Call it GPIB#2) in a computer to read commands sent by another GPIB interface (PCI-GPIB) located in another PC (call it GPIB#1).   GPIB#1 is the CIC and is configured from NI-Max to be the system controller. GPIB#2 is configured to NOT be the system controller.
1. I can use the straight DLL calls (IBWRT,IBRD etc) to communicate between these two computers, so I know hardware and software are configured correctly.
2. I want to use the CWGPIB control on my forms, but whenever I perform the configure method I get "ERROR 30331 GPIB Board not Controller in Carge (CIC)"
Anyone have any ideas?
Thanks in advance for any help.
Ned Bennett
GDS Software
(6,344 Views)
Hello Ned,
The CWGPIB control is designed to communicate with a device on the gpib bus, and not for board level communication as you are wanting to perform.  I would recommend that you use the functions from the DLL to perform this functionality.
Jason S.
(6,336 Views)
