Measurement Studio for VB6
VB6 and daqmx c api primer
Hello, I do not have Measurement Studio but would like to use VB6 to control the USB6015 board and DAQmx driver, mainly analog in.  From what I can tell, this would be accomplished via the DAQmx C api.  Is there some sort of documentation/primer on the available functions, their description, syntax, I/O, etc, and how to use them within a VB ap?
Thanks, Bob
(6,447 Views)
Bob,
Once you download the drivers here(http://digital.ni.com/softlib.nsf/websearch/D31D46FFFB745ECA862571490053EAB8?OpenDocument), you will get the documentation and some example programs that should get you started.  Here is another link that explains where to find the examples. (http://digital.ni.com/public.nsf/websearch/B22FE2B0F9C8935286256E920073DA07?OpenDocument) I hope this helps.  Have a great weekend!
L. Allen
(6,436 Views)
