Measurement Studio for VB6
VB6 and daqmx c api primer
Hello, I do not have Measurement Studio but would like to use VB6 to control the USB6015 board and DAQmx driver, mainly analog in.  From what I can tell, this would be accomplished via the DAQmx C api.  Is there some sort of documentation/primer on the available functions, their description, syntax, I/O, etc, and how to use them within a VB ap?
Thanks, Bob
(6,657 Views)
Bob,
Once you download the drivers here(https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html), you will get the documentation and some example programs that should get you started.  Here is another link that explains where to find the examples. (https://www.ni.com/en/support/documentation/supplemental/21/using-ni-daqmx-in-text-based-programming...) I hope this helps.  Have a great weekend!
L. Allen
(6,646 Views)
