05-16-2009 04:51 PM - edited 05-16-2009 04:52 PM
I am trying to figure out how to what my options are for running my VB6 apps that use the NI-DAQmx C API with either Vista or Win7.
I have some applications that we have been maintaining in VB6 (with Measurement Studio 6). Originally I programmed the software for Traditional NI-DAQ hardware. Which I guess I have been using for about 10 years or so. About 2 years ago or so we had a need to use our software with newer DaqMX hardware so I was able to use the NI-DAQmx C API for Visual Basic 6.0. My application actually supports both hardware platforms simultaneously. The person responsible for the project wanted to have 1 single application that handled both platforms (daqmx and legacy). It is all great so far.
Would anyone know what my options are if I want to use Windows Vista or Windows 7. We currently are running this app on Windows XP. I am prepared to upgrade my software if necessary although I will have to move over to VB.net and Measurement Studio 7.1 (what I presently own). But if we needed to switch over tomorrow is there any compatilibility. I read that Traditional/Legacy NI-DAQ is not supported in Vista (and Win7). I googled and found there was a beta that seemed to weakly to support Legacy but did not support USB devices which is what I have (6020e (legacy), SCXI (daqmx), 6259 (daqmx). I have heard that Windows 7 will have a Virtualization system for XP applications that don't run natively under Win7 but for whatever reason I doubt that NI hardware and drivers will run this way.
Also, should there be any differences between Vista and 7? I am an XP user and most of the computers I support are XP so I really don't have any Vista experience. I am planning on installing the Windows 7 RC to try some of this stuff.
thanks, David 🙂
Solved! Go to Solution.
05-18-2009 02:25 PM
05-18-2009 03:31 PM
David,
From my understanding, Windows7 is basically the same engine as Vista but with a new user interface. NI's DAQ drivers might work with 7, but I doubt NI has done any testing with the new OS since it is just in release candidate.
I know NI did release a beta T-DAQ driver for Vista, but they make it seem like they have not extensively tested it. I found that link here.
If you want your program to work, it might be best to use Vista, if you want to play try 7.
Let me know what happens with 7, I am curious.
05-19-2009 10:00 AM
Hello David,
A good resource to see which DAQmx driver is reccomended for various devices using Vista can be found here
-Abram
05-19-2009 10:17 AM
Mark, Thanks for replying. I have a quick question regarding these newer versions of Measurement Studio (MS).
I was not aware that MS supported VB6.0 in later versions but since I was primarily developing VB for NI-DAQmx traditional/legacy hardware I did not ever need to use VB6 with newer versions of MS.
Does MS 8.x allow you to use VB6 to program NI-DAQmx devices? I assume that is the case.
Also, have most people that are using DAQmx hardware switched over to .net development?
05-20-2009 09:52 AM
For more information on your questions, please see the KnowledgeBase articles Are Applications Written in Visual Basic 6.0 That Use Measurement Studio for Visual Basic 6 Compatib...
Programming NI-DAQ in Visual Basic 6.0
and the Measurement Studio homepage.
05-20-2009 01:33 PM
Mark,
Thanks for the information.  I went through it and it refreshed my memory about conversations I had with NI in 2007 and 2008.
Like I said previously at some point I will migrate over to Visual Studio .net with the latest version of of Measurement Studio. Switching over
will not be all that painful. Switching over will force me to clean up my code anyway. I could try migrating my VB6 code over to .net but I do think that I do want to update my code so it is more object oriented.
I am still hoping that someone may have info on running my NI-DAQ traditional hardware drivers in an XP virtual mode in Vista or Win7
05-20-2009 01:33 PM
Mark,
05-21-2009 10:57 AM
Use of our released Traditional DAQ drivers is not supported on Vista systems, even running in a Windows XP virtual mode. The driver works at a lower level than what a virtual mode can emulate.
We do however have a public beta for a Traditional DAQ driver that works for Vista. You can read about this beta here
-Abram
05-21-2009 11:21 AM
Abram,
Thanks for your posting. I was wanting confirmation about the virtual mode. Although it is not what I wanted to hear it is what I suspected.
Knowing this reinforces my plans to convert over to using NI-DAQmx compatible hardware.
For my older systems that are using Traditional DAQ hardware (like my 6020E USB Daqpad) I can stay with XP and my VB6 apps.
For the stuff that I am developing on DAQmx hardware (my SCXI package). I will use my current VB6 apps that work with DAQmx (and assume they will work) but quickly I will start using VB.net, and the latest Measurement Studio. Here I can stay with XP but at some point in the near future move to Vista or Windows7 all with the DAQmx driver.
David
