Measurement Studio for VB6
Vision resample2 function ERROR
I am acquiring a 2048 x 2048 imaq image which I save in a raw format, but I would also like to save a smaller thumbnail 512 x 512 TIF image of the scene as well.
I am using the Resample2 function in the following method
Dim imaqimage as new CWIMAQImage
Dim resample_imaqimage as new CWIMAQImage
*acquire the image into imaqimage*
CWIMAQVision1.Resample2 imaqimage, resample_imaqimage,cwimaqinterpolatebilinear, 512, 512
And I get the error, "Incompatible Image Type"
(7,237 Views)
Hi timmkish,
Upon looking at this code, my first instinct is a mismatch in the file types.  Have you seen the following lines in the help document?
Resample2 Method
Use this method with U8, I16, SGL, HSL, and RGB32 images.
SourceImage and DestImage must be the same type of image.
Are you sure that your source and destination images are the same type? If not, this could be the issue.
Stephen Meserve
(7,221 Views)
Where is the help file located and what is it's filename?
The image I acquire is a 12 bit image.
(7,216 Views)
Hi timmkish,
The help file is located at
C:\Program Files\National Instruments\Vision\Documentation\cwimaq.chm
Stephen Meserve
(7,212 Views)
