Measurement Studio for VB6
Why does VB6 think my CWGraph is an evaluation copy?
I have 2 PCs. They both have these items installed.
1. VB6
2. NI Software (from Control Panel | Add or Remove Programs)
3. NI Measurement Studio 6 (from Control Panel | Add or Remove Programs)
4. NI IMAQ Vision 6 for Measurement Studio (from Control Panel | Add or Remove Programs)
In the VB6 IDE on one PC, a CWGraph is an 'evaluation copy'. On the other PC, it is not. I want the CWGraph to not be an 'evaluation copy'. What do I do? I can see no difference in the environments of the 2 PCs.
Bill Swartz
Software Engineer
Optomec
(7,469 Views)
Hi Bill,
On your Measurement Studio 6 CD, there is a directory called ActiveX License Fixer Utility, run the executable under this directory to see if it fixes the licensing for the activeX controls.  Let me know if this resolves the issue or if you still see the evaluation messages after running it.
(7,457 Views)
The ActiveX License Fixer Utility resolved the issue. Thanks
Bill Swartz
(7,449 Views)
