Measurement Studio for VB6
generate front panel based on xml description
Is there a method to read an xml file and generate a front panel based on the description contained in the xml file?
(7,173 Views)
Hello mcu_guy!
Thanks for contacting National Instruments!  This sounds like more of a Visual Basic 6.0 issue rather than a Measurement Studio issue, so perhaps Microsoft will be a better reference for you?   One great resource is Microsoft's Developer Network (MSDN).  I have also taken the liberty to dig through some of the documents I've seen before regarding dynamic creation of Form objects and I believe that this KnowledgeBase article on the MSDN should be a great start for you.
Best of luck with your application, mcu_guy!
Derrick S.
Product Manager
NI DIAdem
(7,158 Views)
I apologize.  I thought I posted this on the Labview forum.
Thanks for the info.
(7,153 Views)
