Measurement Studio for VB6
a CWGraph is an 'evaluation copy'
I use "windows 8.1, VB6, Measurement &  automation"  to work for  a long time, everything is running well, but my computer broken last mouth,
then I refresh my computer and reinstall all program,
1. install VB6 with windows 8, (upgrade to windows 8.1     2 day late)
2. install NI driver 9.0.2  ( support VB6)
3. install " Measurement Studio 8.1.2 Enterprise Edition for Visual studio 6.0 " from Labview 2010 DS2 DVD ( no install Labview)
the message show "Runtime Error!  Program: H:\Distributions\MS_VS6\setup.exe      R6025 - pure virtual function call" then exit
I use my software setup file to install  & run my software( try register old version to the computer),the .exe file working well,
 when I open the software with VB6 to edit,  it show cwui error "error loading control. A newer version needed. the default setting for the control will be used."
and CWGraph is 'evaluation copy' ( the other component ex: CWButton,CWNumEdit  is OK ), How can I fix? somebody can help?
thanks!
ps: Labview 2010 DS2 DVD not for windows 8 but it's last version with  " Measurement Studio 8.1.2 Enterprise Edition for Visual studio 6.0 "
(7,925 Views)
I'd guess that your Measurement Studio version isn't compatible with the OS.  If you look at the compatibility chart for LabVIEW and Windows, Windows 8 does not support LabVIEW 2010.  I would imagine that this also applies to Measurement Studio.
(7,908 Views)
Thanks! Dsum
I do same  install for the last computer (around 2013) , it working well
any suggest ?!
(7,900 Views)
What was the OS on your last computer?
(7,860 Views)
same! windows 8 then upgrade to 8.1
(7,850 Views)
It seems like your Measurement Studio version is not officially supported on Windows 8 according to this article: http://www.ni.com/mstudio/product-lifecycle/
You could try going through re-install procedures but it seems like the installation behavior will be inconsistent and unreliable.  I would suggest an upgrade to your Measurement Studio version.
(7,840 Views)
thanks!
look like no Measurement Studio  version can match with windows 8.1 & vb6
(7,818 Views)
