Measurement Studio for VB6
data acquisition Ni - 6341USB, using drivers NIDAQmx on VB.net
Hi there, i have a problem using MyTask.Timing function.
I would like to know how I can controll the samplerate frequency; while using MyTask i noticed that it doesn't make the expected cycles but only the first.
I can only control the data sampling rate on Matlab with the .Rate option, but  i couldn't control it directly using VB.net
Thank You.
Private Sub btSTART_Click(sender As Object, e As EventArgs) Handles btSTART.Click
        NC = NumericUpDown1.Value 'numero di cicli
        Dim cycleIndex As Integer = 0
        If isJustHomed = True Then
xHome = Math.Round(AxMintController1.get_Pos(0) * CConv, 4)
End If
   Dim Vel(Ns - 1) As Double
        AxMintController1.set_Suspend(0, 0) 'Remove "hold"  to the engine
HoldBox.Checked = False
        Dim myTask As New Task                                 ' Assign a name to "task"
myTask.AOChannels.CreateVoltageChannel(ComboBoxMo.Text, "MOTOR", Convert.ToDouble(tbminMo.Text), Convert.ToDouble(tbmaxMo.Text), AOVoltageUnits.Volts)
myTask.Timing.ConfigureSampleClock("", TextBox7.Text, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples)
        Dim writer As AnalogSingleChannelWriter = New AnalogSingleChannelWriter(myTask.Stream)
  Do
            For I As Integer = 0 To Ns - 1
            Vel(I) = v(I) * kV
            'writer.WriteMultiSample(True, Vel) 'synchronous
writer.BeginWriteMultiSample(True, Vel, Nothing, Nothing) 'Asynchronous
myTask.WaitUntilDone()
xStop = Math.Round(AxMintController1.get_Pos(0) * CConv, 4)
            NC -= 1
            Label3.Text = NC
            TextBox11.Text = xStop - xHome
        Loop While NC <> 0
(5,789 Views)
you can find working examples in the following folder:
"C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DotNET4.5.1"
If they're not in "public" folder, search for it into your account name folder.
Teo.
(5,434 Views)
