Measurement Studio for VB6
error 2920 while install a measurement studio application
Plateform: MS Visual Studio .net 2003 ent. arch.
NI Measurement Studio (Trial)
OS: MS Windows XP
I used one of the examples from Measurement Studio (BasicSignalGeneration) to build my practice VB project.
After I built the Setup project for installation. I got error 2920 during installation.
Here is the detail information from event log:
Event Type: Error
Event Source: MsiInstaller
Event Category: None
Event ID: 10005
Date: 8/25/2004
Time: 11:07:55 AM
User: N/A
Computer:
Description:
Product: SetupNIi -- The installer has encountered an unexpected error installing this package.
This may indicate a problem with this package. The error code is 2920.
T
he arguments are: cwds.chm1.0DED9891_8CB9_41F7_A2A0_A7E11270DB0A, ,
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Any help is very much appreciated,
Min Shiei
(7,213 Views)
Hey Min,
There is a problem with the datasocket merge modules in Measurement Studio 7.0 that causes the 2920 error. This problem is fixed with Measurement Studio 7.1. The solution for Measurement Studio 7.0 is as follows.
1) Exclude datasocketserver.msm and datasocketcore.msm your Visual Studio .NET setup project and build the installer.
2) Do a two-part install on the target computer:
a) first run the installer for the LabVIEW 7.x Runtime Engine (which installs the DataSocket 4.1components) (this is available as a free download on our website)
LabVIEW Runtime Engine
b) Next run your installer, which will not fail because the DataS
ocket MSMs were excluded and the DataSocket 4.1 components have already been installed.
There is also an installer for DataSocket 4.1 which I could e-mail you or put on our ftp site if you don't want to install the LabVIEW runtime engine.
Please let me know if this doesn't fix your problem or if you'd like me to send you the installer.
Sarah Miracle
(7,213 Views)
Thank you Sarah:
Can you please email the DataSocket 4.1?
Min
(7,213 Views)
Hey Min,
I don't actually have your e-mail address. But if you e-mail into our support line I can reply back with the installer. Just go to www.ni.com/support and follow the directions in the request support box. Be sure to select e-mail NI and only select Measurement Studio as the product you're working with. In the text of your e-mail include my name (Sarah) and I'll get it.
Thanks!!
Sarah Miracle
(7,213 Views)
