Measurement Studio for VB6
how to upgrage softwares using measurement studio 1.6 with ones using measurement studio 1.7
If we just want to send an exe to a customer without installing the software again. What will be the content of a patch.
(6,301 Views)
I don't understand your question. There was never a version 1.6 or 1.7 of Measurement Studio. If you are talking about your EXEs version then there is a question you have to ask yourself.
Did you upgrade Measurement Studio between your EXEs version? If so then you need to create another installer to upgrade not only your EXE but the Measurement Studio components on the system. If not then you should be able to just copy the newer EXE over the older EXE.
Jeff
NI
(6,301 Views)
Sorry, in fact it was version 6 and version 7 of Measurement Studio.
My question must have been : if I install new exe with New Measurement Studio components. Which dll, ocx,... must I include in the installer.
For instance, If I only include cwui.ocx, mesa.dll, mfc42.dll, msvcrt.dll and register them in the installer (Since I only use CWGraph control from Measurement Studio) will it work properly or must I check other parameters?
(6,301 Views)
Sorry, it was version 6 and 7 of Measurment Studio.
My question is rather : if I only include cwui.ocx, mesa.dll, mfc42.dll, msvcrt.dll in the installer because I only use CWGraph Component, will it work properly or must I check other parameters?
(6,301 Views)
If you are now using Version 7 of Measurement Studio with Visual Studio .NET 2003, you should follow the deployment guidlines in the help. Deployment has changed drastically between version 6 and 7. With Visual Studio .NET's new deployment capabilities things are much easier and you do not have to worry about registering or installing any of our stuff. You just include the correct installer merege modules, and your built project's output.
See the help:
ms-help://MS.VSCC.2003/NI.MeasurementStudio/Integration/static/Distributing_MStudio_Apps.html
The help topic outlines using the technology and what merge modules are necessary for what Classes you used in your application.
Jeff
(6,301 Views)
Thank You
Nathalie
(6,301 Views)
