02-06-2006 10:45 AM
02-07-2006
05:19 PM
- last edited on
05-15-2025
03:49 PM
by
Content Cleaner
driverhelp,
nidaq32.dll is the dll for our legacy driver, Traditional NI-DAQ. The most recent version is 7.4.1. Note that this is a hardware driver for our data acquisition products. If you do not have any NI hardware, then this example is not likely to function correctly.
If you do have NI DAQ hardware, instead of using this example written in Traditional (Legacy) NI-DAQ, I would consider using our latest driver, NI-DAQmx, which can be downloaded here. When installing either of these drivers, they will prompt you to add support for specific development environments. Be sure you select your version of Visual Studio and you will have all the examples you should need to get started programming with our data acquisition devices. Please let us know if you have any questions!
Hope this helps,
Message Edited by Voltage Viper [DE] on 02-07-2006 05:20 PM
