11-29-2005 03:41 PM
11-30-2005 07:25 AM
I also tried the solution in:
http://forums.ni.com/ni/board/message?board.id=250&message.id=12976
but I am already in the user group with full permissions.
11-30-2005 07:27 AM
11-30-2005
05:10 PM
- last edited on
07-10-2025
09:42 AM
by
Content Cleaner
Hello Saroj,
From the looks of that line of code that you sent it appears that you are using or trying to use Component Works commands to call your DAQ board.
ComponentWorks uses our older Traditional DAQ calls, so you will not be able to use DAQmx 8.0 if you want to run that program. Instead, you will need to install Traditional DAQ 7.4.1 and it should allow you to run that program and avoid the error.
07:29 PM
- last edited on
07-10-2025
09:42 AM
by
Content Cleaner
Alternatively, you can use DAQmx in VB6. See this article for more information:
https://www.ni.com/en/support/documentation/supplemental/21/using-ni-daqmx-in-text-based-programming...
12-01-2005 07:29 AM
12-01-2005
08:38 AM
- last edited on
07-10-2025
09:43 AM
by
Content Cleaner
12-02-2005 10:33 AM
12-02-2005 10:45 AM
