Measurement Studio for VB6
using Measurement Studio tools on PDAs
Is the latest version of Measurement Studio compatable with the .net compact framework?
I'd like to be able to use some of the Measurement Studio objects in an application to run on a PDA running PocketPC 2003.
(8,319 Views)
Neither the current version of Measurement Studio (7.0) nor the next version of Measurement Studio support the .NET compact framework. We are evaluating the possibility of creating versions of the class libraries that support the .NET compact framework at some point in the future.
Could you give us a basic idea of what you are trying to do and what class libraries or controls you would need for the applications you would want to run on a PDA?
(8,315 Views)
Whats the status of the compact framework class libraries of Measurement Studio?
(8,091 Views)
Regretably, we have not seen enough customer interest for Compact Framework Measurement Studio class libraries to justify the development expense. I will document your inquiry.
Any additional information about your needs would be useful to me in documenting your request. For example, which controls, libraries, and hardware (e.g., analysis, DAQ, serial) would you use, what types of applictions you would develop, how many development licenses would your request would cover, and how many run-time licenses (if we were to choose to have run-time licenses for the Measurement Studio Compact Framework libraries) would you need per year.
Some PDA application scenarios can be covered with the ASP.NET controls. If your PDA application just needs to act as a display for a headless device (such as a PXI chassis), you could implement an ASP.NET application on the headless device and access it from a web browser on the PDA via a wireless network. Would this work for your application or do you need a rich client on the PDA?
(8,084 Views)
 The voltage measurements (analogue input channel) and the digital input channel need to be displayed on the PDA.
No need of graphs, just the reading.
Message Edited by Mayu on 07-05-2006 07:54 PM
(8,073 Views)
