Measurement Studio for VB6
using daqmx with measurment studio 6 and VB6
Hi
Can I use a NIDAQmx only device with Measurment Studio Enterprise 6.0 and VB6?
If not, what is the minimal upgrade I need to do in order to start using NIDAQmx with VB6?
Shai
(7,403 Views)
Hi Shai,
If you are using NI-DAQmx in Visual Studio 6.0, you will need to work directly with the type library file for NI-DAQmx.  Refer to the Programming DAQ in Visual Basic 6.0 and NI-DAQmx Support in Visual Basic 6.0 KnowledgeBases for further help.
Best Regards,
Jonathan N.
(7,389 Views)
Thanks, It works!
Can I also control M series and other USB devices with this method (i.e. using Visual Studio 6, not Visual Studio .net)?
Shai
(7,375 Views)
Hi Shai,
As long as the device is supported in DAQmx, you should be fine. If its a traditional device, you can use our CW ActiveX controls.
Best Regards,
Jonathan N.
(7,370 Views)
