hello..thank for the reply.
i'm having problem with my coding using cwgraph. can anyone help. everytime i do the full compile, there's error.but it can still can run, but can't convert to application form.for your info, i'm using RTscope and cwgraph to plot graph.the error is in the cwgraph coding.below are part of the coding with error. and can somebody tell me how to add cwgraph component in the VB? i try adding component, but it's not in the list of component,and i've browse for it already too.i'm doing the software at home, but i'can run it at my lab cause cwgraph component is not listed.please help.
Dim countTime As Integer, count1 As Integer, countFreq As Integer, countVolt As Integer
Private Sub cmdRun_Click()
If cmdRun.CausesValidation = True Then
cmdPause.CausesValidation = False
tmrOsc2.Enabled = True
tmrOsc3.Enabled = True
Else
tmrOsc2.Enabled = False
tmrOsc3.Enabled = False
For count1 = 0 To 100
Data1(count1) = 0
Data2(count1) = 0
RT1.Value(1, count1) = 0
RT1.Value(2, count1) = 0
RT1.Refresh
CWGraph2.Plots(1).PlotY count1 ' THIS CODING HAS AN ERROR ...
CWGraph2.Plots(2).PlotY count1 ' THIS CODING HAS AN ERROR ...
Next count1
End If
End Sub
