Measurement Studio for VC++
Asynchronously Writing Digital ports
I am using PCI-6221 and DAQmx 8.7.2 and C# for programming
I want to write digital ports first, and after it completes, it will get a single sample analog input.
Here is my program.
Can anyone point out the problem ? Because I used step-by-step debug, the AnalogSingleSampleRead() is not executed.
namespace NItest
public partial class Form1 : Form
//global variables
private double data;
private Task digitalWriteTask = new Task();
private Task AnalogTask = new Task(); private DigitalMultiChannelWriter ThreePortsWriter;
private AnalogSingleChannelReader myAnalogReader;
byte[,] DOutputss = new byte[3, 8];
public Form1()
   InitializeComponent();
   initNI();
private void initNI()
digitalWriteTask.DOChannels.CreateChannel(Port0, "", ChannelLineGrouping.OneChannelForAllLines);
digitalWriteTask.DOChannels.CreateChannel(Port1,
digitalWriteTask.DOChannels.CreateChannel(Port2, "", ChannelLineGrouping.OneChannelForAllLines);
digitalWriteTask.Control(TaskAction.Verify);
ThreePortsWriter = new DigitalMultiChannelWriter(digitalWriteTask.Stream);
digitalWriteTask.Start();
AnalogTask.AIChannels.CreateVoltageChannel("Dev1/ai0", "", AITerminalConfiguration.Rse, 0, 5, AIVoltageUnits.Volts);
AnalogTask.Control(TaskAction.Verify);
myAnalogReader =
new AnalogSingleChannelReader(AnalogTask.Stream);
AnalogTask.Start();
ThreePortsWriter.SynchronizeCallbacks =
true;
}//end of iniNI
 private void DAQmxAsyncWrite()
   //[give some value to DOutputss]
   IAsyncResult handle=ThreePortsWriter.BeginWriteMultiSamplePort(false, DOutputss, new AsyncCallback(myCallback), null);
private void myCallback(IAsyncResult ar)
    ThreePortsWriter.EndWrite(ar);
    data = myAnalogReader.ReadSingleSample();
When I call DAQmxAsyncWrite(), the program never execute myCallback().
Why please?
Thank you all.
Message Edited by timinmanchester on 11-29-2008 08:48 AM
Message Edited by timinmanchester on 11-29-2008 08:49 AM
Message Edited by timinmanchester on 11-29-2008 08:51 AM
(6,288 Views)
duplicate post
Message Edited by Hillman on 12-05-2008 01:56 PM
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(6,239 Views)
