Measurement Studio for VC++
Bounded print all recursively
hello,I had a C++ exam which I did well except the last problem.
the last problemSmiley Sad
 Let m,n,and sum be positive integers.In this problem we are interested in length-n arrays whose entries are integers in the set{1,2,....,m} such that the sum of the enteries of the array is less than or equal to sum.
  Write a recursive function,which given m,n,and sum,prints all such arrays.Your function should also compute the total number N of those arrys.
Examples:
 For m=3,n=3,and sum =4,the function should print
1  1  1
1  2  1
2  1  1
thus N=4
 For m=3,n=3,and sum=5,the function should print
1  1  1
1  1  2
1  1  3
1  2  1
1  2  2
1  3  1
2  1  1
2  1  2
2  2  1
3  1  1
thus N=10
 Form=3,n=4,and sum=6, the function should print
1  1  1  1
1  1  1  2
1  1  1  3
1  1  2  1
1  1  2  2
1  1  3  1
1  2  1  1
1  2  1  2
1  2  2  1
1  3  1  1
2  1  1  1
2  1  2  1
2  2  1  1
3  1  1  1
thus N=15
The time of your function should be in the order of the output size N(and not m to power n).That is ,you are epected to avoid recursive branches which do not eventually lead to valid arrays.
Which way is the best way to solve this problem,I used a for loop,and placed inside it the same recursive function.What kinds of parameter should have I used(I used a pointer to an array,int,int ,itn)
I did not know the base case so I placed When I occurs final time.
(7,001 Views)
Hey Frodo,
nice question 😄 However, the answer you are asking for would be better to discuss with your proffesor or on some general programming or algoritmization forums, instead of measurement focused one.
Stefo
(6,955 Views)
I wish I can help you, but from the moral stand point. I rather not.
(6,940 Views)
Accepted by topic author Frodo Baggins
 Any body wants the solution,figured it out
(6,935 Views)
