Measurement Studio for VC++
Building resource name?
Hi Gang,
It's been a frustrating day.
I'm building an application driver for the PCI-6021 in native C++.  I'm using the DAQmx driver inside of it.  It appears that the driver needs C-type strings (array of type constant character) for  the "counter" specification.
All works well when I create the below and pass that to the function:
char My Counter[10] = "Dev1/ctr0";
But, I need to build the character array by casting and inserting integer variables for the device and counter numbers.
I can build strings that have the right text in them, but I haven't figured out how to cast that into a variable that will work with the command.
I know this is more of a C/C++ question, but I'll really appreciate all help.
Roger
(6,316 Views)
When the function help states that it requires a const char[], it is simply letting you know that it needs read-only acces. If you provide it with a char[], then it will make the conversion for you and work just fine. Below is some code I was able to run properly.
        char chan[256];
	strcpy(chan, "Dev1/ctr0");
	chan[8] = '1';
	DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,chan,"",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
(6,309 Views)
That doesn't help me.
I've also been able to build a string, inserting a char literal, using the "strcat()" function.  The problem is that the device number gets passed in as an integer (this driver must be compatible with existing software).  I can implicitly cast that by this code:
int MyIntArg = 1;
char MyChar = MyIntArg;
Then replace the character:
MyCounter = "Devx/ctr0" ;
MyCounter[3] = Mychar;
This compiles without error, but the counter doesn't run.  It only runs when character literals are used.  So far, I haven't figured out what the issue is.  When the function doesn't run, it returns -200220, which seems to be a type exception error.
I appreciate all help.
Roger
(6,303 Views)
Accepted by topic author RogerMont
Eureka!!
I found a workaround.
I create an array of character literals:
char Numbers[9] = {'1','2','3','4','5','6','7','8','9'};
int MyIntArg = 1;
MyCounter[3] = Numbers[MyIntArg -1];
Whew!  On to the next problem!
Roger
(6,301 Views)
