Measurement Studio for VC++
call labview dlls in release mode
Hi all,
I built a LabVIEW dll for the bluetooth connection, at the beginning I called this dll in the VS C++ in the debug mode, it worked very well.
but due to the application, all the code should run in release mode. Unfortunately error occured, " Runtime error, R6030 CRT not initialized".
I googled, but i did not get something useful.
I appreciate any comments and  information, and apologize for my poor english.
ps.  I tried to use different runtime library, and finially I got only multi-thread DLL was suitable.
(7,118 Views)
the attachments are the VC code and the dll files,
I really appreciate any comments about thie problem.
(7,088 Views)
Have you tried the solution posted on this forum post?
Rohama K.
(7,076 Views)
yes, I tried this solution before. and you can find my relay on that post,
if I change the runtime library to the multi-threaded rather than multi-threaded DLL, the code can work in release mode, but I hope it work in multi-threaded dll.
Thanks for reply, do you have any other comments?
Sample
(7,070 Views)
I ran your project in release mode and had it set to multi-thread DLL and I did not get the error you were getting. When I ran the code, a command window printed:
first print
Did not find bluetooth devices.
Any ideas on how I would reproduce your error?
Rohama K.
(7,062 Views)
Thanks for reply and tried my project on your computer.
I dont know man, I still have  the same problems now. maybe you made some advanced setting. Let me list what setting I made in the VS,
in the C++>>General>>additional Include directories, I add these header files' path, the BTinit.h BTloop.h , BTend.h and the cintools folder for necessary labview header files.
in the Linker>>General>>additional library directories, I add these libraries' path,
in the Linker>>input>>Additional Dependencies, I added BTinit.lib, BTloop.lib, BTend.lib.
That's all. I did it in the debug mode, and it worked there.
Is there something different with yours?
Any further information are appreciated.
Sample
(7,055 Views)
Hi Sample,
I am using VS2010. Attached it an txt file that lists all my settings. Hope it helps.
Rohama K.
(7,048 Views)
