Measurement Studio for VC++
Button Controls Disappearing
This is an FYI...
I've had a problem with buttons disappearing when using CFormView.  The same problem as discussed in the knowledgebase link below.
http://digital.ni.com/public.nsf/websearch/862567530005F09F86256726006E261F?OpenDocument
I found that doing the following will work around the issue:
  1. We had to select all of the controls (Ctrl+A) in the dialog.
  2. Shift + left click to unselect the NI buttons that were not working properly.
  3. Press the delete button
  4. Ctrl+Z to undo. (make all of the controls re-appear)
  5. Test this by pressing CTRL+T to test the dialog or run your application.
I hope this helps!
Message 1 of 1
(6,055 Views)
