Measurement Studio for VC++
measure studio 8.0 error
when i use vs2003 ,new to setup measure mfc application,meet error,like below:
An unexpected error has occurred.
   at EnvDTE._DTE.LaunchWizard(String VSZFile, Object[]& ContextParams)
   at NationalInstruments.VSDesigner.VS.VsDTE.LaunchWizard(String vszFile, Object[]& contextParams)
   at NationalInstruments.Cpp.ProjectWizards.CppProjectWizards.RunWizard(Object[]& contextParams)
   at NationalInstruments.VSDesigner.Wizards.VsProjectWizard.Execute()
   at NationalInstruments.VSDesigner.Wizards.VsWizard.Execute(Object application, Int32 hwndOwner, Object[]& contextParams, Object[]& customParams, wizardResult& retVal)
(6,230 Views)
Hi z12345678,
I see that nobody has responded to your message so I was wondering if you are still having problems? By the nature of the message, the first step to try would be to perform a repair on Measurement Studio as it seems something is corrupt with the integration between VIsual Studio and Measurement Studio.
Best Regards,
Message Edited by Jonathan N on 04-29-2007 08:37 PM
Jonathan N.
(6,206 Views)
