Measurement Studio for VC++
CWGraph3D Not Showing
I just transfered all of my VC++ projects to another Win2K machine.  I have CWGraph controls and a CWGraph3D control in my program.  When I run the code, however, the CWGraph3D control shows up blank, whereas the CWGraph controls show up and function just fine.  I didn't have this problem with my previous setup and I know I transfered and installed everything correctly.  The current setup is:
Win2K
VisualC++ 6.0
Measurement Studios 6.0
The PC is about the same year old and the same setup as the previous one so I know the upgrade of any of the above is not the solution.  I would really appreciate your wise advice.  Thanks.
Jeffrey
(4,321 Views)
CWGraph control is in CWUI.OCX file, while CWGraph3D control is in another.
(4,316 Views)
I am sorry but I don't quite understand your advice.  Could you elaborate a little bit?  Thanks.
Jeffrey
(4,312 Views)
Jeffrey,
I think what he is saying is that there are separate files that support the WaveformGraph and 3DGraph.  The WaveformGraph uses the cwui.ocx and the 3DGraph uses the  cwgrah3d.ocx.  It may be an issue with your distribution of the files.  Did you install Measurement Studio on both machines?  Or did you just copy the ocx files from one computer to another.  If you are attempting to distribute an application, I recommend following the instructions for found in this link:
http://digital.ni.com/public.nsf/websearch/3509FC64EC2E3715862568A100624468?OpenDocument
Let me know if you are still having problems.
Tyler Tigue
(4,294 Views)
