Measurement Studio for VC++
Issue with DAQmxCreateAIFreqVoltageChan
I have a 6008-USB card and NI-DAQmx 7.5.
Every 10 seconds, I have to measure frequency of a pulse train (from
3000 to 4000 Hz, TTL level).
I wrote the following code, but when I compile and run it (MS VC++ 6.0)
I always got this output:
Frequency is:
-92559631349317831000000000000000000000000000000000000000000000.000000
Where I am mistaking??
Here is the code:
float64 f; /* frequency */
DAQmxCreateTask("Frequency",&taskHandle);
DAQmxCreateAIFreqVoltageChan(taskHandle,
"Dev1/ai0",
3000,
4000,
DAQmx_Val_Hz,
0.0,
0.2,
DAQmxStartTask(taskHandle);
while( !_kbhit() ) { /* hit any key to exit */
Sleep(10000);
DAQmxReadAnalogScalarF64(
taskHandle,
10,
&f,
0);
printf ("\rFrequency is: %f Hz", f);
(3,497 Views)
Rossi,
The USB-6008 does not support frequency measurements in hardware. The 6008 can only do simple even counting. So you can set it up in software to measure frequency, but only at low frequencies ( <50Hz or so). Here is a KB describing this if you would like some more information. It also describes how you can set up the software frequency measurement. I hope that has been helpful.
-GDE
(3,493 Views)
