 jes1789
			jes1789
			11-05-2009 12:31 PM
11-06-2009 04:40 PM
Hello jes1789,
I am not sure what you mean when you say that both drivers cannot be installed at the same time. They most definitely can. Only one driver can control the card at a time though. The bigger thing that you have to watch out for is not all devices work with each driver. A number of our newer devices will only work with DAQmx and some of the very old DAQ cards will only work with tDAQ. You can control different cards within the same application with different driver.
Unfortuneately, there is no clean answer for you. The drivers cannot be used interchangeably and you will need to have an application that either uses all tDAQ or all DAQmx. I don't know of any better answer for you, but I invite anyone out there to post if they have a better option.
