Measurement Studio for VC++
NonLinearFit for matrix
Hi!
I would like to make a best sphere fit on a matrix of points. This is existing in LabView but I could not find it in Measurement Studio.
The LeastSquaresFit() method seems to do the fit only regarding to a plane.
I then found the NonLinearFit() function which I guess could have helped me.  But this one work only in one dimension: the input set of data is a vector and the description of the model function is a one dimensional function.
Could you help me with this?
Is there another way to make a spherical interpolation of a surface with CNiMath?
Thanks in advance for your help!
(6,306 Views)
Hi Alia,
opening the "Fitting on a Sphere.vi" in LabVIEW, you can see that it incorporates only a small amount of mathmatics to reduce the problem into a regular linear-equasion solving problem:
So if the SpereFit is not directly available in Measurement Studio, why not D-I-Y? 🙂
Sebastian
(6,287 Views)
I don't have LabView and I don't know LabView.
Anyway thanks...
(6,285 Views)
