Measurement Studio for VC++
ComponentWorks on client server enviroment
I created an application using CWUI components (cwgrap, cwknob...). Is there a way to run this application in a client server enviroment, where my app was installed only on the server. No software can be installed on the clients, and the application will be executed from a shered folder.
(2,920 Views)
Unfortunately there is not a way to do this. The Measurement Studio UI controls are ActiveX controls and they require installation and registration on the client machine. Once you have the ActiveX controls installed, though, you could run your application from a shared folder.
- Elton
(2,920 Views)
