Hello
If you are using Visual C++, then I would recommend using the NI-DAQ function calls instead of having labview layer in there. YOu can pretty much accomplish any task using the NI-DAQ function calls that you can by using the LabVIEW DAQ vi's. Plus this way you wont have to worry about passing the correct data type from LabVIEW into C++. You can find the examples for using these function calls under ../NI-DAQ/Examples/.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
