Measurement Studio for VC++
Context Menu on CniGraph 2D
I use MeasurementStudio 6 ( vers 7 0 0 343) with Visual C++ 6
I will wish to make a contextual menu on a graph 2d to change the TrackEventmode.
In Ni Example �Simple graph� I add the function �OnMouseDownCwgraphmouse� if Button is ButtonRight I call TrackPopmenu function with two items zoom, cursor.
cursor set TrackDragCursor, zoom set TrackZoomRectX.
After this call cursordrag and zoom never work, pan is OK.
If I comment the line pmnu->trackpopmenu all is working.
Where are my mistakes?
Thank in advance for your help..
(3,662 Views)
Hi ras
Can you provide me a sample code which reproduce your
problem. I'll try to see what's going wrong with it.
Regards
Salissou ISSA
Applications Engineer
National Instrumnents France
(3,662 Views)
hello,
Thanks for your help.
On attached file SimpleGraph.zip you can find the original Ni sampleGraph and my modifications, they are signed "// jlr".
Regards.
PS: Ni France ? are you in France ? my english is still a beta release french is better for me.
(3,662 Views)
I have the same problem. I Track the popup menu and all the functionality like zooming are gone. If I track the menu with the pointer to the CNiGraph instance it works, however all the menus are grayed out. Does anyone have a solution for this?
Miklos
(3,662 Views)
