Measurement Studio for VC++
Continuous Writing to Digital 2520 Card (using DAQmx C API)
Hello, Im trying to develop an application that can continuously write an array of 80 elements to the PXI-2520 card.  Each element corresponds to an individual line (channel).  Im struggling with the following:
1.  how do I Create the DO channel ?  do I create Dev1/port0:9 using DAQmx_Val_ChanForAllLines?
2.  which write API do I call in order to write the elements of the array to each line?
3.  the data is always updating, so in order to keep the output up to date, do I need to call the write function in a loop?
Appreciate any insight.
Message 1 of 1
(1,583 Views)
