Measurement Studio for VC++
DAQMx(USB6363) AO hi-z(off) method?
I'm using USB-6363 and I'm changing the simple AO output voltage. After all the changes, I want to make the AO voltage hi-z (off, it's not zero) and I want to know how to do it. It's hard to find a discussion about it.Below is an example of AO voltage change.
int error=0;
TaskHandle taskHandle=0;
char errBuff[2048]={'\0'};
float64 data[1] = {1.0};
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ao0","",-10.0,10.0,DAQmx_Val_Volts,""));
// DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
// DAQmx Write Code
DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
// DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
printf("DAQmx Error: %s\n",errBuff);
printf("End of program, press Enter key to quit\n");
getchar();
return 0;
Message 1 of 1
(1,631 Views)
