Measurement Studio for VC++
Data array size limit @ 129491 float64s
I do not have measurement studio, but am trying to interface s-series NI-DAQ hardware using the NIDAQmx.h interface.
My problem boils down to the following in a c++ console application project (visual studio 2005):
#include <NIDAQmx.h>
int main(){
       float64 data[128*128*6];  //98304 64-bit numbersor 786432 bytes (not a megabyte)
 This compiles and runs just fine.
If I increase the allocated size of the data array over 129491 (float64s), the program compiles fine but when I run the console program, I get an unhandled windows exception.  Now that number is just shy of 20-bits of addressing for bytes, but it's not like it's exactly on the number or anything.
I'm going to continue to look around for a solution, but if anyone can help, That'd be grand.
Thanks!
Message 1 of 9
(8,925 Views)
Hey Gus,
Is there a reason we're using float64 rather than float or double?   Since we haven't called any National Instruments hardware at this point, the issue might be where we're calling float64 from (not a standard primitive in VS).
Clarification: addressing is done on the bit level, not the byte level
2^22=4,194,304
2^23=8,388,608
float64data[98304]   is 6291456 bits (  786432 bytes)
float64data[129491] is 8287424 bits (1035928 bytes) ~0.988MB
-John Sullivan
Problem Solver
Message 2 of 9
(8,900 Views)
Memory is addressed at a per byte interval.  That's why you can only have 4 gigaBYTES of memory on a 32 bit processor (2^32).
To move from one CHAR to the next requires you index your char pointer by one.  This increments your &ptr value 1 where pointers are 32 bit numbers.  64 bit numbers are indexed by increasing a pointer value by 8 (i.e. 8 bytes).
When I mouse over "float64" in visual studio, i get the "#define double float64" command from the NIDAQmx.h include.
I believe my problem has something to do with a page file size in windows.  I've worked around the issue to some extent by switching to 16-bit numbers and reading fewer of them at a time for processing.  This makes the system overall faster anyway.
But eventually I'd like to deal with images and such and having a size limit on this scale could prevent buffering several images in memory.
Message 3 of 9
(8,896 Views)
Hey Gus,
You're absolutely right!  Pardon my incorrect word choice.  What I was trying to say is that a 64 bit number times the size of your array yields a bit value that we can divide down.  This is where I derived my calculations from.  Were you not able to get 32 bit numbers to work, or did you drop down to 16 bits for a specific reason?
-John Sullivan
Problem Solver
Message 4 of 9
(8,880 Views)
I just moved on from the issue.  I went down to 16 bits because the NIDAQ is only 12-bit resolution.  I don't need more than that precision and I don't need signed numbers.
Message 5 of 9
(8,878 Views)
If you run into more problems with this issue in the future we can look into it a bit more.  I'm curious to see if we can use float32 (float) with this setup.
-John Sullivan
Problem Solver
Message 6 of 9
(8,869 Views)
One more thing I'll mention is that we do have a beta for DAQmx 8.9 that provides native 64 bit support.  You can sign up for this beta at ni.com/beta.
-John Sullivan
Problem Solver
Message 7 of 9
(8,868 Views)
Accepted by topic author Gus-HHMI
Hi Gus,
The default stack size for applications compiled with Visual C++ is 1 MB. Note that the OS and C runtime use some stack space before your main() function is ever called, so you have slightly less than a megabyte to work with. You can increase the stack size using the Visual C++ /F option, but a much better approach is to allocate the array on the heap instead (using malloc()/free() or new[]/delete[]).
Brad
Brad Keryan
NI R&D
Message 8 of 9
(8,770 Views)
Makes perfect sense.  I was creating this array in a function that would frequently lose scope and thus free the memory.  I was also unaware of this limitation.  Thanks for the info, that solves my question.
Message 9 of 9
(8,766 Views)
