Measurement Studio for VC++
VC++ upgrade from VS6 to VS.Net 2005 problem - NIVisa.h
We are late on the bandwagon and finally trying to upgrade to .Net. All of my projects have been working/compiling using Visual Studio 6 and we are upgrading to Visual Studio.Net 2005 (specifically 2005 for a reason in case you are wondering why we don't go all the way up to 2008).
I got many of my projects converted already, but lately got stuck on one.  I started getting a compiler error that it couldn't find NiVisa.h. I searched the directories and found where it was located and made sure it was in the Visual Studio directory listings to search for header files.
Now it finds NiVisa.h, but i get lots and lots of errors that seem to come straight from NiVisa.h.
Is there a newer version of the NiVisa.h header I should point to instead of NiVisa.h? Or is there some other fix or suggestions anybody has?
(7,249 Views)
Accepted by topic author KingTermite
Hey King,
You get the most recent version of NiVisa.h when you install the NI-Visa driver. To fix the problems with your .h file please go to http://joule.ni.com/nidu/cds/fn/p/sb/navsRel/lang/en?q=Visa&x=0&y=0 download the driver, and install. Make sure you select support for Visual Studio 2005 in the installer. If this doesn't solve your problem, can you please include a listing of the errors on your next post?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(7,226 Views)
Aaaaah! That's probably it. Thanks.
I uninstalled everything from NI and reinstalled to get fresh versions for .net development. I assumed it was part of Measurement Studio. I probably didn't install NiVisa.
Thanks.
(7,224 Views)
Just a follow up, that was exactly the problem. Thank you!
(7,208 Views)
