Measurement Studio for VC++
Global variable JNI
I am creating a java application to use "NI USB-6008" and other models.
To do this, I created a class (Card.java) that has the methods needed to work with the card. Write files .h and .c and gender "card.dll". View files:
  • Card.java
  • Card1.c
To create Card.h I write in console:
javac Card.java
javah -jni Card
The problem I have is that "card.dll" takes from 3 seconds to respond. As a solution, I chose to create global variables static (Card2.c) but I get the error: "Failed to write core dump. Minidumps are not enabled by default on client version of Windows"
To create card.dll I used Dev-C + + and jdk7
Am I doing something wrong?
Message 1 of 1
(5,715 Views)
